Too much power to components?
  • 4
BreakThisBread
I'm considering purchasing HAT Imagines and powering them with my US Amps Md22 which puts out 200 @ 4 and I know headroom is a good thing, but is this too much? If so is there a proper way to still use this amp without overpowering them? Can I turn the gain down? I really don't want to go through the process of selling the amp and buying another.
Yes you can turn down the gain and be fine,
good thing about that is you can set with a dmm to exact watts u want and know you are not clipping from the gain too high
as stated above you can use a dmm to set it to the exact watts you want it putting out or take it to a local car audio shop and they will probably help you out and tune it but for a price
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
BreakThisBread
BreakThisBread
Beautiful California
BreakThisBread
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
