New to car audio and I'm in the process of putting together my first build.
So far i have a Skar 800.1 pushing a vvx-15 in a 30hz ported box.
I'm interested in the 85.4 for my front stage and can use suggestions on what comps to look for.
Open to other amp suggestions as well.
My price range is between $150-$250 for comps.
Would also like to know what you guys think of the build itself and what direction I should take it.
I mainly listen to rap music and I'm leaning towards more sql than spl but then again I dont know what would go well with my current sub stage.
Specs for 85.4
4ohm 85 x 4
2ohm 125 x 2
4ohm mono 250 x 2
Frequency Response Hz (-3dB) : 20~30k
Signal to Noise Ratio (dB) : 105
Damping Factor : 200
Low Level Input : 6V-0.2mV
Line Output : Yes
Remote Level Knob Included : Yes
Power/Protection Indicators
4 Gauge Power and Ground Terminals
Dimensions (mm) : 350 L x 241 W x 64.5 H
Specs for 85.4
4ohm 85 x 4
2ohm 125 x 2
4ohm mono 250 x 2
Line Output : Yes
