How to install Eclipse IPC-106 to Eclipse AVN52D
Pistonsfan70
I am a novice when it comes to car audio install, but like to learn as I go. I bought the IPC-106 recently, and figured it would be an easy plug & play install but I am STUMPED!! Here are the pictures. Do I need an adapter?? Is it not compatible? (although I have seen many people selling their same combo after use, not talking about Sonic Electronix)
Any and all help is appreciated!!!
Youre missing the pig tail that plugs into the back of the AVN52D...it has the opposite end of the round plu your holding.
It plugs into one of those empty white plugs on the HU.
Yeah, now I am just learning how to wire up the power. First time for everything!!! If there is a specific link that shows how to wire the ground and power (whatever the black and yellow wires are called from the IPC-106), I would appreciate it!
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
744
Thank you for your kind replies. I have decided to use an amplifier I purchased for another install, but subsequently never used. I was...
940
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Pistonsfan70
Pistonsfan70
Detroit Area, MI
corey2409
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
