FS old school crossfire cfa602 and more!
12voltz+-
lorain OH
2 - crossfire cfa602
1 - cfq20x
1 - cfx23
both amps work great ! little tanks i have heard of people running down to 2 ohm daily with no issue with about 800rms out of each. these amps can also do 3 channel mode!! you can have about 100 to 150rms per channel while at the same time gettin 600rms from 1ch for a subwoofer !
works great!! a few blemishes on the chassies of then dip here and there but none the less **** amps
the cfq20x is a 20 band eq per side works great only bad is that there is 3 of the little sliders broken off but the still function if you get a small screw driver and slide the pot back and forth !
cfx23 is a front and rear 4ch input that will split to 3 outputs with crossover and its own controls
can also do high pass low bass and bandpass!!
no clue what to price these goodies at how about
- 125 per amp
- 35 for the eq
- 20 for the crossover
send me a zip code ill get exact shipping if every thing bought at once i can do free shipping
any questions just ask ill do what i can to find you the info if you want more pics let me know
Hmmm !! Dont need anything ATM, but 4 anyone needing some power, and a GOOD DEAL!! This IS certainly worth considering!!!!Nice set of Crossfire equiptment you have there !//content.invisioncic.com/y282845/emoticons/awesome.gif.4430a219d9aaaa6cadc75e9290979dfb.gif
it was posted on one of the link i did a post above you ! lol
it will do 3 ch mode 100rms x 2 at 4 ohm and 1 x 600rms at 4 ohm.... you will need a inline inductors/ passive crossovers for the sub tho :/
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
12voltz+-
12voltz+-
lorain OH
VanLan
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
