40x Batcap 2000 Look-a-likes
RAM_Designs
SketchUp Master
21,735
Rockwall, TX
I will only trade for a solid 2kw at 1ohm(or 4ohms).
Item(s) for Sale: 40x DataSafe batts
http://www.osibatteries.com/p-933-enersys-datasafe-npx-150rfr-sealed-lead-battery-12v-150w-formerly-yuasa.aspx
DataSafe NPX valve regulated lead-acid batteries are designed for high rate discharge applications. These batteries are used primarily where high wattage is required for a short duration. With 50% more wattage available and a 30% reduction in size over conventional batteries, DataSafe NPX batteries offer a superior value.
These DataSafe batts are made by Enersys, who also makes Stinger, Hawker, and Odyssey batteries...which we all know are pretty well respected. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
- Sealed/maintenance-free - no water to add
- Sealed construction - can be operated in any position without leakage
- Rugged construction - high impact ABS plastic cases
- Rechargeable sealed lead acid battery
- Lead-calcium VRLA (AGM) technology
- 34.1lbs
- Dimensions: 7.76"L x 6.50"W x 6.89"H
- Resting at 12.9-13V
- Threaded inserts for easy connections
$105 shipped each
$100 shipped if buying more than one
$80 each for locals
Included in price, will be shipped via FedEx
it usually takes me 2 and a half to get to Longview...how far you from there? i may hit Tyler for Turky Drags but haven't saw the date yet...I don't have anything big in any vehicle right now though so Im not sure...if Ill make it
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
3K
The last piece and the system is a wrap, RUX-H02 remote volume/sub knob because we are old and buttons **** IMG_0647 by Jon Polo, on Flickr...
5
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
Chris Gerrish
    Apr 25, 2024
vlusardi
    Apr 24, 2024
Latest topics
