Nut Hair Trick 10+ year member
Pubes
Item(s) for Sale: Used db Drive pt2000.1D amp that I acquired in a trade a little over a month ago. I hooked it up one time to see if it takes power and it works fine. It's been sitting uninstalled since then because my system build isn't ready.
Item(s) Description/Condition: This amp can be ran on a 18v setup, and it can be ran @.25 daily. Here is a bench test that was done on one of these.
Clamped at using 50hz:
4128 RMS @ .25ohm/14.4v
3168 RMS @ .5ohm/14.4v
2304 RMS @ 1ohm/14.4v
1161 RMS @ 2ohm/14.4v
586 RMS @ 4ohm/14.4
Looks like a sweet amp to me but I need something with a smaller footprint. The only flaw to this particular amp is the plastic feet that come on it. The 2 bottom holes where you mount the amp are snapped off. I'm sure there is a way to get around this if you were to want to mount the amp vertically, because the top holes are just fine.
Price: $300 or trade for AQ2200
Shipping and Miscellaneous Item Information: Buyer pays shipping and paypal fees
586 RMS @ 4ohm/14.4
