Hpf & lpf
  • 3
hotrod351
24
arizona
this is probably been asked 100s of times, but here goes again. LPF ans HPF settings, i search omline and find answers for settings them both to 80HZ to setting the LPF to 80HZ and the HPF to 100HZ or even 120HZ. im running three amps, one for door speakers, pioneer 6.5" and one for my two 8" JL audio subs. ive tried both settings but seem to go back to 100HZ for the HPF. my LPF is 80HZ.
LPF for your subs should be around 80hz in rare cases sometimes 100hz but most people usually don't like the sound. If your doors aren't deadened or the speakers are low quality you may prefer a higher HPF due to a limited amount of mid bass. All in all it boils down to what sounds good to you, not just some rule of thumb that you need to follow.
thats the feeling im getting for all the settings. get a basic setting and go from there. really it sounds good to me now. leave it alone and enjoy. thanks
tried 120 and 100 on HP and 100 sounds best to me. seems it all depends on speakers, speaker location and how your hearing is.
Hpf set to 80hz door speakers really shouldn't play lower than that without specific design inputs ie: sealed doors, fully deadened doors, mounted...
The HU us likley 12-15 x 4 at best so yes, using an amp will be hugely beneficial, night and day. The HU us not going to drive a sub to any...
65
https://www.amazon.com/dp/B07DLC9M48/?tag=caraudiocom-20
25
234
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
248
hotrod351
hotrod351
arizona
hotrod351
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
