ok so im getting a car that has a 8 speakers
  • 4
optimusprime
roll out.
well actually it will have 9
two 1 inch tweets in dash
one 6.5 inch speaker in each door
two 8 inch speakers in the rear deck lid
one 12 inch sub in the trunk
my question is would it be a goo idea to use a 4 channel for the doors and run the tweets off the HU a mono for the sub and a 2 channel for the rear 8's? or would it be better to use a 4 channel instead of a 2 channel and mono block?
I'd get a set of comps for the front. Insert in oem locations for both mid/tweeter(Not sure if you meant a sep tweeter and a reg 2 way speaker in the door). Pick whatever rear 8's you want for the rear. For the f+r i'd just get a 4ch. Size of said amp depends on what kind of 8's you decide to go with. Then just get a mono amp for the sub. Depending on what sub you go with you could possibly just get a bigger 5ch.
You could always make 6.5 coaxils fit in the rear aswell.
My car had a similar setup with tweets in the dash, door speakers, and subs in the rear deck. I have everything running off a single 4ch amp now with passives on the front and the rear speakers replaced with IB subwoofers running off bridged channels. If I wanted a dedicated big sub in the trunk, I'd still use the 4ch for the interior speakers and use a 2ch/mono for only sub-use.
Here are the reasons of my assumptions and why I think there is little danger in this setup. 1. Bared conductors could cause a spark that leads...
38
4K
Appreciate the input! I'll check out the calc site and see how it compares. I'm in the beginning stages of building the box. Unfortunately with...
561
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
I'm putting 2 under my rear seats with 2 passive radiators. Only a 3kw amp. Only reason I'm selling my adire subs before even trying them. Granted...
20
optimusprime
roll out.
optimusprime
westbrook, ME
BnGRacing
    Apr 17, 2024
HandsomeSteve
    Apr 16, 2024
