Henry De Roche 10+ year member
I have been reading up on this stuff, but haven't found anything that talks about different impedance of speakers...
No the drivers... ohms is resistant so when one driver has less resistance then the other itll be getting more power then other there for hurting them when you try and push the 8 ohm speaker as hard as the 4 ohm... In a nutshell anywayIt can't be done without hurting the amp?
Thats cuz in bridged mode that amp is only stable at 4 ohms... wiring at 3 like stated above will hurt your ampI have it wired into the only place that will take speakers and its labled bridge, I wired each one what I thought was into the two seperate channels. It was red to the +and black to the-
