Southwest Region Arizona State welcomes IASCA, Thanks Mike Jaffe :)
AZ,CA,NM,NV,UT
  • 5
Competitors may use test tones and/or sine sweeps for competition in Stock
Division.
Got it..
The maximum size power and ground wiring allowed in Stock Division is 1/0
gauge wire. One (1) ―run‖ of power wire and one (1) run of ground wire per
amplifier is allowed from the battery/ies to the additional battery/amplifier/
distribution block.....
I have the DD M4a it has two runs for +/-????
Competitors may use test tones and/or sine sweeps for competition in StockDivision.
Got it..
If you have 2 runs of positive going from the battery to the amp, that is a no go. But, you can do one run or 1/0 positive from the battery to a distroblock, then run two 1/0 to the amp. Same with the ground. Sorry, I had to read the book too. I printed it out for tmw. Can you get a 1/0 disztro block? Maybe make a "Y" with ring terms, might work.
Got it..
I am not sure if we met Friday. I never where my hearing aids at shows. so I never catch names right away.
This show was one long *** night. it went from 430pm to 1230am. Definately could have been shorter and faster but it was nice.
I ran across some haters of course. for some reason people always have to play the made in america card. which doesnt mean much these days.
I ran the IDBL and had fuses in. but I forgot to drop the impedance to .75 ohms.
I ended up with a 144. but I still placed first.advanced 2
subzero
subzero
Chandler, AZ
subzero
Bobbytwonames
    Apr 20, 2024
Bobbytwonames
    Apr 20, 2024
