Changing dust cap on Fi BTL
Jager
I keep blowing the dustcap off of my btl. It is starting to pull the cone up. and it looks ugly. Can I get a larger diameter dustcap to cover where the old one went and where the cone started to peel, or will that make the sub sound different?
The BTL probably has a 6'' or smaller dustcap on it, so you can put an 8'' on it. Fixmyspeaker.com has them as do a few other companies. The sub should sound the same after the dustcap change.
Yea I wish I would have just used CA glue, but a lot of people on here recommended Goop... and it did a horrible job. The dustcap started coming of at a comp, and a guy there had ca glue and he fixed it for me, and the CA is holding strong, but the other half that was still help down by goop has pulled apart again. Ill take pics to show what im talking about, I just want a bigger dust cap to hide the peeling cone
You're donitrong. Goop > CA glue for dustcaps. There's a couple guys around here that do 160+ and that's all they use. I do a lot of recones and I've had far fewer fail that I used goop on.
This could be due to a voltage drop. There's no constant voltage going into the head units. It's always changing. At which point this could be...
8
Simply put its an oldschool simple way of keeping the midbass in phase with each other when they are firing at each other in the front...
743
I am about to buy the Pioneer DMH-WT76NEX head unit. It has one USB Type C output. My Honda has an HDMI port, 2 USB-A ports, and one charger...
Haters are going to hate. It usually goes back to something personal. He would probably take it in his dirty penny to have a full Sundown sub and...
24
5K
Jager
Jager
Alexandria, MN
hispls
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
