cman0655555 10+ year member
Sundown Audio SAZ-3000d
• 9/10 cosmetic
• 10/10 function
• Used but in great condition. Has a very small nick in the heatsink but isn’t bad at all. Other than that looks brand new.
SAZ-3000D
• Double Sided Through Hole Epoxy PCB
• Efficiency : 86% @ 4 ohm, at 100Hz
• 24dB/Oct Variable Crossover
• Multi-Way Protection Circuitry
• (Thermal/Over Current/Speaker Short/Speaker DC Protection)
• Variable Subsonic Filter
• Variable Bass Boost
• Variable Low Pass Filter
• Variable Phase Shift
• Zero(0) Gauge Power Supply Connectors
• Tested Voltage & THD : 14.4V & Less than 1% THD
• Operating Voltage : DC 10V~18V
• Digital Class-D Linkable Mono Block Amplifier
• 1 Ohm Stability
• RCA Line Input and Master Output
• 24dB Octave Crossover Slope
• Wired Remote Controller
• MSRP $1549 USD
• Rated power output
• RMS power, 2 ohm linkable/dual mono 6000W x 1CH
• RMS power, 1 ohm mono 3000W x 1CH
• RMS power, 2 ohm mono 1600W x 1CH
• RMS power, 4 ohm mono 800W x 1CH
• Signal to Noise Ratio >90dB
• Low pass frequency crossover 35Hz~300Hz
• Subsonic filter 10Hz~60Hz
• Bass boost @ 45Hz 0~18dB
• Phase shift control 0~180 degree
• Frequency response 10Hz~350Hz (+/- 1dB)
• T.H.D @ 4 ohm
• Fuse rating 300A (external type fuse)
• Input Sensitivity 200mV to 6V (+/- 5%)
• Dimensions 252(W) x 53(H) x 594(L)mm
500+actual shipping
Only trades would be for a dual 2 10 or 12'' FI Q, Sundown Z series or similar +cash on your end.
Have original packaging and boxes from sundown which will be used to ship. I will insure as well. If you are local or close to me would be willing to meet halfway or deliver for a reasonable fee.
Pics are older but it has been for sale for a while on local forums with no luck. Nothing has changed its just been sitting around. I can get newer pictures if desired. Also can get pics of the packaging/boxes if desired. Its just sitting around and I thought I was going to be upgrading but in turn will be downgrading to save space. Thanks
• 9/10 cosmetic
• 10/10 function
SAZ-3000D
• 1 Ohm Stability
• MSRP $1549 USD
• T.H.D @ 4 ohm
500+actual shipping
