Jump to content
cman0655555
Sundown Audio SAZ-3000d
Recommended Posts
• 9/10 cosmetic
• 10/10 function
• Used but in great condition. Has a very small nick in the heatsink but isn’t bad at all. Other than that looks brand new.
SAZ-3000D
• Double Sided Through Hole Epoxy PCB
• Efficiency : 86% @ 4 ohm, at 100Hz
• 24dB/Oct Variable Crossover
• Multi-Way Protection Circuitry
• (Thermal/Over Current/Speaker Short/Speaker DC Protection)
• Variable Subsonic Filter
• Variable Bass Boost
• Variable Low Pass Filter
• Variable Phase Shift
• Zero(0) Gauge Power Supply Connectors
• Tested Voltage & THD : 14.4V & Less than 1% THD
• Operating Voltage : DC 10V~18V
• Digital Class-D Linkable Mono Block Amplifier
• 1 Ohm Stability
• RCA Line Input and Master Output
• 24dB Octave Crossover Slope
• Wired Remote Controller
• MSRP $1549 USD
• Rated power output
• RMS power, 2 ohm linkable/dual mono 6000W x 1CH
• RMS power, 1 ohm mono 3000W x 1CH
• RMS power, 2 ohm mono 1600W x 1CH
• RMS power, 4 ohm mono 800W x 1CH
• Signal to Noise Ratio >90dB
• Low pass frequency crossover 35Hz~300Hz
• Subsonic filter 10Hz~60Hz
• Bass boost @ 45Hz 0~18dB
• Phase shift control 0~180 degree
• Frequency response 10Hz~350Hz (+/- 1dB)
• T.H.D @ 4 ohm
• Fuse rating 300A (external type fuse)
• Input Sensitivity 200mV to 6V (+/- 5%)
• Dimensions 252(W) x 53(H) x 594(L)mm
500+actual shipping
Only trades would be for a dual 2 10 or 12'' FI Q, Sundown Z series or similar +cash on your end.
Have original packaging and boxes from sundown which will be used to ship. I will insure as well. If you are local or close to me would be willing to meet halfway or deliver for a reasonable fee.
Pics are older but it has been for sale for a while on local forums with no luck. Nothing has changed its just been sitting around. I can get newer pictures if desired. Also can get pics of the packaging/boxes if desired. Its just sitting around and I thought I was going to be upgrading but in turn will be downgrading to save space. Thanks
Share this post
Link to post
Share on other sites
whats the best price to 19525?
Pm sent.
---------- Post added at 12:58 PM ---------- Previous post was at 12:58 PM ----------
Please no offers on trading other amps as I have all I need currently. Also have no use for anything that is a bigger than a 12'' sub as I cant fit it. Thanks for the interest though.
Share this post
Link to post
Mines has the model number in both corners, and it's full of fins on the side, can they be strapped? Or are they like the aq3500.1 where it gets a little smoky in the car if the newer one mixes with the older ones?
I didnt think they made 2 versions of the 3000d but I may be wrong. To my knowledge they would be strappable. I know you can strap the v1 1500's and v2 1500's and not have any problems. Someone feel free to correct me if I am wrong. Are you sure you dont have a 3500?
Share this post
Link to post
Anyone got an answer to this?
Share this post
Link to post
My 3000 also has it in both corners, I think ours is the newest release of 3k. Strapping them together should work, idk for sure though
Share this post
Link to post
Guest
This topic is now closed to further replies.
  • Recently Browsing   0 members
    No registered users viewing this page.
  • Similar Content
    • By Telegon80
      3.2 megapixel still & video camera with 10x optical zoom and 10x digital zoom (100x). Ill include a 128MB SD card with it.
      for a product review and all the product specs go here:
      http://www.imaging-resource.com/PRODS/OPTMX/OMXA.HTM
      pics:
      $150 obo, no dibs no nothing, first with money gets it. if shipping it will go fedex ground with emailed tracking updates. ill trade straight up for a SLVR, Ipod or PSP
      pm or aim abrandnewsentra
      k thx
    • By J31Rob
      Nike Air Jordan Retro 8 VIII Playoff 305381-061
      Condition: Like new in box, worn 2 times.
      Price: $120 shipped
    • By J31Rob
      I need the unit AS SOON AS POSSIBLE.
    • By connersdad19
      This Was Pulled From A Working Machine. I am asking 35 Shipped. Will need to have a new copy of windows installed. Comes with cable as well.
      ST3500630AS Barracuda 7200.10 SATA 3.0Gb/s 500-GB Hard Drive | Seagate
    • By connersdad19
      1 - Avermedia Analog/Digital TV Tuner with 3-D Combination (PCIe) Model #M791-B
      Ports:
      * One Analog TV
      * One ATSC antenna
      * One S-Video
      * One Stereo audio mini-jack audio
      SOLD...comes with only the card No Box/Software.
      2 - Agere Systems PCI Pinball P40 56k Modem SV92PP Chipset
      $10 Shipped
      3 - Crucial 2x1GB 240-Pin DDR2 667 (PC2 5300) CT12864AA667
      $25 Shipped
      4 - Intel E2180 Dual Core 2.00ghz/1MB L2 Cache/800mhz (Comes with cpu fan that has been cleaned of thermal paste. $50 Shipped
      5 - Samsung Writemaster DVD/Cd Burner (IDE) Model #SH-202G
      Sold
      6 - 2 80 mm fans and 1 120 mm fan. The black one is a 2 pin off brand fan the others are coolermaster fans that are 3 pins and have blue leds. $5 Shipped
      7 - Intel E210882 Motherboard (pulled from a Gateway desktop) I have the back panel for it if needed. $40 Shipped
      8 - Seagate Barracuda 7200.10 SATA 3.0Gb/s 500-GB Hard Drive
      will come with the sata cable SOLD
      All of these Items are used but were pulled from a working machine and are in excellent condition.
