Making a custom 6.5" bracket in my '04 GP
  • 2
blabo219
Well i've never done a custom MDF bracket for door speakers so heres how I plan on going about it but please let me know if there's a better way.
Cutting a 3/4" MDF ring to sit the woofer in just as wide as where the screws go in, so 1/2".
Now I was going to try to make a square with four supports going to the sheet metal and fasten those in, with whatever is suggested, maybe some T-nuts.
Then I was wondering, since the supports are in a square should I make a box around the four sides, just leaving the speaker hole to the door open? not sure if it would improve mid bass seeing as how I already have damplifier pro on my doors.
Suggestions please!
Self taps 1", 1 1/8" and I wounding bother with a pod unless your gonna get technically and figure out what size the pod needs to be to work right. Other than that I would just suggest cutting the first plate a little bigger than nessecary and trim it down to what is needed cause you can cut wood down to fit but u can waste a piece if it is too small. And make sure the driver and passenger will be the same I've had a few cars where they have to be made a lil dif side to side
Well it was hard to get any useful info out of there with your proper grammar..
Does it matter the size/shape of the "pod" i figured its not really a box so it can't be causing any harmful effects on the sound.. other than maybe the fact that it might perform better free air?
725
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
blabo219
blabo219
Battle Creek, Michigan
blabo219
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
