xbrandonxx 10+ year member
I am getting ready to look at a kenwood KAC-X520. the question i have is will this amp push my jl audio 10w7? these are the stats for the amp:
125 watts RMS x 2 at 4 ohms
250 watts RMS x 2 at 2 ohms
500 watts RMS x 1 at 4 ohms in bridged mode
Stereo or bridged mono output
Tri-Way capable
Infrasonic filter (15 Hz, 24 dB/octave)
50-200 Hz crossovers: 12 dB/octave high-pass, 18 dB/octave low-pass
12 dB bass boost variable from 40-100 Hz (expandable to 6/12/18 dB when connected to a Kenwood Excelon receiver equipped with BMS controls)
Bass Management System
Preamp outputs
Fan cooling
Speaker short, low battery, thermal overload, and DC protection
Variable color indicator
Gold-plated terminals
Requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
2" wide detachable terminal covers
17-9/16"W x 2-5/16"H x 12-1/2"L
Tri-Way capable
Preamp outputs
Fan cooling
