kicker amps
  • 6
354
891
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
MrMckie
MrMckie
Hartford, CT
MrMckie
Chris Gerrish
    Apr 25, 2024
vlusardi
    Apr 24, 2024
