Haha.. I Should Know This By Now.. (623Posts)
  • 4
n0ftInc
Spoilers Up. Kula Style.
Alright, I was thinking about buying a component set. Here is an example to help me figure this out.
So a 2-Way set says 100wts RMS. Does this mean I should look for an amp rated at 100x2 to run them, or since there is 4 speakers, should I look for 200x2..?
I feel so ashamed.. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Alright, next question..
Orion 2002..
2 x 50 watts @ 4 Ohm
2 x 100 watts @ 2 Ohm
1 x 200 watts @ 4 Ohm
Components..
RMS: 100W
Impedance: 4Ohms
Would I be able to hook these up to get the 2 x 100 watts @ 2 Ohm..?
I can, can't I..?
yes, you can't. Same on you for asking such a noob question.
On another note, 50w+ RMS (orion amps should be under rated) is more than enough for a lot of comps, 50w will get mighty loud.
Wait..
..So there is no way I can send out 100 x 2 to a set of 4Ohm componets? Even if I connected them in a 2Ohm load?
you would get a 2 ohm load for 1 channel if you wired them like that. so you would get 100 X 1 and 0 X 1 because you wouldn't have a speaker hooked upto the other channel.
The CT's are nice, That Sundown is a a frik'n beast!
7
524
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
477
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
565
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
888
n0ftInc
n0ftInc
A Foolish Pleasure In MI..
BooLeaN
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
