How to strengthen pre-fab sub box
  • 3
pilotdog68
12
Omaha
I am somewhat lazy and dont have access to many tools, so I went out and bought a cheap box made out of ~5/8 mdf. I didnt realize how important box strength is. Some people say you can strengthen the box by adding dowels, or by coating the inside with polyester resin. one guy said he painted the inside with wood glue. do any of these work or are they all bull? if they do work, do they do enough to be worth the cost/hassle? are there any other suggestions for a quick fix? its a 10" sealed .70cf box, will run a 300wrms sub.
thanks for helping the newb here
Anything you do will be more or less just a band-aid. The enclosure is VERY important! But... polyster resin, or anything that you can use to make it as air tight as possible will help. Dowel rods (3/4"-1") will help as well.
your enclosure isn't large enough and you're not putting enough wattage to make a difference. only thing you might want to do is put a little extra silicone on the inside to ensure and air tight seal. anything else you do is just wasting money.
I just bought an Alpine R-A75M for my sub woofers, and later plan on adding the Alpine R-A60F. My plan was to wire these with 3 sets of RCAs; one...
yeah that, just as long as your amp can take the voltage. I have an orion amp that maxes input voltage at 4V.
Sounds like you need new coils. My Explorer with three 15's, appropriate birch box, fully sound-deadened interior, and a boat behind it does not...
Ive competed in car audio since 1991 and unless something is faulty in the amp and its staying on all the time it wont drain your batteries ..the...
pilotdog68
pilotdog68
Omaha
fasfocus00
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
