Autotek Model 99 Old School Zed Audio Built 2 channel amp!
Shinju
Seattle
Autotek Model 99
I have two this is for 1 of these Autotek Model 99's, This amp works 100% and is severly underrated rated.. Cosmetics are ok, This amp has some scuffs and scratches as you can see not bad for a 18 year old amp these hit the car audio scene in early 1994. The internals are flawless this amp is 100% original never been repaired or tinkered with.
The other Autotek amp has some surface rust forming on the face plate.
Both amps have ALL of their Terminal Screw's I just removed the 4 speaker ones to clean up the terminal.
Mean Machine
Output Power at 12V:
2 x 49W @ 4 ohms (0.015% THD)
2 x 175W @ 2 ohms (0.15% THD)
1 x 99W @ 8 ohms bridged
1 x 350W @ 4 ohms bridged
S/N Ratio: 102dB
Built by Zed Audio
Asking 165.00 each or 300.00 for the pair. Not looking for trades at this time! Thanks!
Free shipping CONus only
Amp 1
Amp 2
Amp 1 and 2 Back side shot (both are in the same condition)
Amp 1 and 2 Gutshots both look Identical both work flawlessly
nice!!!! i want one soooooo bad.....i have a 66 and a 88 and the old school 6 way crossover they made when their stuff was top notch.......
I honestly do not understand how this is still here......my cousin use to run four RF 15" subs in a walled off monte carlo with this amp.......it was nasty.......wish i had the monies.......or maybe i can take some gut pics of my 88 that you were interested in and work something out? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Autotek Model 99
Mean Machine
S/N Ratio: 102dB
Built by Zed Audio
Amp 1
Amp 2
Do you still have these if so I want them
Autotek Model 99
Mean Machine
S/N Ratio: 102dB
Built by Zed Audio
Amp 1
Amp 2
I’m interested in these amps please
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
952
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
152
Okay i found one under b stock on alphards shop site but unable to actually place order grrr
Most new radios have that feature. Just check that they have 4 RCA outputs. Those are line output. If it only has 2 RCA outputs, make sure they...
Shinju
Shinju
Seattle
Mitch423
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
