Jump to content
Recommended Posts
Okay, I'm hearing mixed opinions here...some folks are telling me to keep the Cap and get a second battery! They said that the cap will help when that deep bass demands alot of power! as supposed to pulling all of the energy from the alternator....
Are those people telling you to keep the cap members on here?
*Sundown Z15 *SAX-1200D *CDT HD-61A *SAX-100.4 *Pioneer DEH-80PRS *KnuKonceptz *XS Power D3400 *270A Mechman
Sold to: blackbonnie, TheOneJordan, resko1, kr15, Zichardruniga, IBmikexxx, plugitin
Bought from: Gruszka530, theMessenjah44, ltr450racer690, Dpc69ss, 97maxima(Here and ROE), Pillow(CACO), pro-rabbit, woofercooker, Twisted_0912
Share this post
Link to post
Share on other sites
Yeah, i have a couple of guys PMing me telling me to keep it and use it....
Share this post
Link to post
Big3 > caps
I am running an MBQ dsc at 2ohm (750rms) on a stock 90a alt. Prior to big 3 my lights would dim quite a bit volts were dropping. After doing big 3 in 0ga, at full tilt I never even drop below 13.8v. I myself was somewhat shocked by the effectiveness of it. My car idles at 14.4, so I am only dropping .6v...Now obviously, the power you plan is a completely different issue then my punk asss 750rms, but I am just speaking to the effectiveness of it
Team Flex Issues
JVF Customz
REFS- Supergumby5000, Lastcall, 919motoring, hippishake, daboyfromdabx (great seller), beach22
Share this post
Link to post
Big3 > caps
Now Imthinking about ordering some cheaper 1/0 gauge and do my whole systek with it instead of buying and expensice kit for just the amp...
99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
-Head Unit: Kenwood DNX-692HD_____________ -Head Unit: Eclipse CD7100
-Sub Stage: Focal KX40 16"_________________ -Sub Stage: Looking
-Mids/Highs: Focal KRX & PHD AF____________ -Mids/Highs: Scan Speak & Blaupunkt
-Sub Amp: Mosconi AS200.4_________________ -Sub Amp: American Warrior Set (Zed Built)
-Mid Amp: Mosconi AS200.4_________________ -Mid Amp: ^^^
Share this post
Link to post
If you can avoid it, dont skimp out on wire...it defeats the purpose. Wire can only carry so much current, so when you skimp it, you skimp on the current delivery capability so to speak. Buying cheap 0ga that is really only the size of 4ga does no good..4ga is only rated at 125a at the MOST. Not everyone can afford Kicker and Streetwires etc, but shop around and make sure you can get the best wire possible
Team Flex Issues
JVF Customz
Share this post
Link to post
Well I was gunna go with Knu 0 gauge kit but that may not even be enough to reach my amp if it wont fit under the seat and now Im thinkin I may have to do the Big 3 too
Share this post
Link to post
Knu is pretty good. That is what I used. I liked it...If possible buy the kit and then buy like 12feet or so from this site for the big 3...as a matter of fact, if you measure what you need for big 3 and let me know, I might be able to help you..i have plenty of extra wire
Team Flex Issues
JVF Customz
Share this post
Link to post
Is the monster cable 1/0 a quality wire, I think it's 400 series ??
Share this post
Link to post
Its an F-150 so I may need quite abit for the big 3
Share this post
Link to post
Big3 > caps
If your amp is really putting out 750 watts, without even factoring in amplifier efficiency, at 14v, 750 watts is 53 amps. add in 20% waste for heat and it's 63.6 amps.
Headlights, and ignition system can easily be 30 amps, bringing the current draw right up to 93..
I'd say you have a pretty good alternator, and some exceptional wiring with virtually no losses. THERE ARE NO AMOUNT OF CAPS that can do that.
which MBQ DCS amp do you have at 750 RMS? --> MB Quart Car Audio -- DISCUS Amplifers
Share this post
Link to post
Will I have a power drop off, since I will be using 1/0 gauge wire throughout my truck to a distribution block then 4 gauge from the distro block to the amp....the amp only accepts up to 4 gauge....
Share this post
Link to post
You may end up with dimming headlights, but the short run of 4AWG from the dist. block to the amp won't be the cause of it.
Share this post
Link to post
whats a reducer????? never heard of it
Share this post
Link to post
If the amp only accepts 4 gauge, then 4 gauge will be enough.
Or get a better amp.
Share this post
Link to post
I have 2 Orion H2 12.2 subs that will be powered by an Orion 2500D amp at 1 Ohm (I think). I've been searching high and low for all my options. I am going to do the Big3 upgrade for sure but i was thinking about getting a Kinetik HC1800 battery for a secondary battery in the back and I still have my regular Duralast Battery in the front. I'm going to run 0 gauge throughout my truck (2004 Jeep Grand Cherokee). I have a stock 136 Amp alternator.Thoughts?????
I have a '00 GC...the 136A alt will be fine.
upgrade your big 3 in 1/0 & replace the duralast w/ a HC1800 under the hood. no need for 2 batts.
Share this post
Link to post
oh yeah...I think that I'm going to try to find one on ebay...the only thing is the Orion 2500D amp has two inputs for ground and power...will I have to get four of those???even though isn't 2-4 gauge wires equal to a 1/0 gauge????
Share this post
Link to post
If it has 2 inputs, do use a distro block close to the amp and go from 0/1 to two runs of 4
Children are the future… today belongs to me!
Share this post
Link to post
I personaly think using a distro block then running 4 gauge is completel retarded unless its to two amps... I mean seriously your only as good as your weaknesses so running a foot of 4 gauge is gunna have just the same affect of running 17 feet of 4 gauge... Cuz if 4 gauge could run the same current 0 gauge could no one would use it... I kinda picture it as a funnel, you run 0 gauge to 4 then it just get choked and adding a distro seems like it would just ad one more "restriction" to the system... am I wrong?
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Recently Browsing   0 members
    No registered users viewing this page.
  • Similar Content
    • By DoubleKill
      Hello guys, recently I bought an amplifier over ebay.
      The model is: Pioneer - GM 3000 the version with 8DIN connectors at the back, however seller didn't mention that.
      So I spoke to an electrical mechanic who added chinches to this connectors and tried the amplifer locally at the workplace and it's working.
      Whenever I tried to connect it to my car, it does start for a couple of seconds, but the noise is really strange like I have a broken speaker and then it turns off.
      He told me maybe bad ground or something, but I tried on a different car with differents cables and it remain the same issue.
      I thought to myself if the cables aren't strong enough maybe they don't provide the necessary power to supply this monster
      the cables I ordered are these:
      Cables I ordered
      I connected everything as it supposed to be, but it doesn't work at all.
      It starts for a couple of seconds then it turns off, maybe goes in protect mode but I don't understand this very much.
      Any advice appreciated also if you have service manual for this model: Pioneer GM-3000 I will be very happy.
    • By Jimmy Moses
      I'm trying to set up subs in my 2002 Chevy Malibu for the first time. I cant find the firewall to save my life, we found it on the outside of the car going to the battery but have no idea where it goes to. We've tried to run a metal coat hanger through it to see where it goes but it didnt seem to work. Does anyone have a clue on where it is? Any help is very appreciated.
    • By ekah
      i have the crescendo pwx 6.5 these are really good but i dont like that i limit them at 5600 hertz and want speakers more on the higher vocal area where theres
      https://gpcaraudio.com/deaf-bonce-apocalypse-ap-m60a-v2/
      im not sure if ill hear a big difference or not where the deaf-bounce goes to 14000 hertz. would i get about the same amount of midbass or more with the deaf bouce?
      the pwx aint in any sort of enclosure its just in my door, someone told me it has to be properly enclosed to get any sort of real midbass but i feel my sub handles all the bass so whats the real point of midbass? might as well have my mids do some clear vocals.
      its being powered by a ppi900.4 at 4 ohms its suppose to be pushing 145rms.
      another question is if my pair of tweeters and mid speakers are running active to my amp how does my head unit know whats a mid and whats a tweeter when i do the crossover through the headunit?
      like if i set my crossover for my highs as low as 5600 and my midbass to 5600 to take over how does it know which speaker or channel is suppose to be at what hertz?
      and are bassblockers caps necessary for my tweeters?
    • By Nodnelcom
      I'm getting 2 rocksford fosgate P2D2's and am looking for a somewhat budget friendly amp. My budgets around 750 for everything and would naturally stay around the low side of it but I don't want to cut down on quality by any means. I've had one set up before but didn't comprise it myself so any tips and knowledge would not but turned away, so any information about anything is welcome.
    • By camry2007
      Hello any help thanks in advance
      2007 Toyota camry looking to hook subs to the factory radio. Any ideas of the best way to do it? thanks for any help
