04 530i System Build.
Mike465
Ami Creations
2,858
Kennesaw, GA
Ok everyone this is a local customers 04 BMW 530i that we replaced everything in and built out the trunk along with doing a full HID setup as well.
Equipment.....................
Front stage
Polk DB 5-1/4" component system
Rear fill
Polk MM series 4x6 plates
Processing
Audio Control DQL-8 with DDC
Sub Stage
Single Sundown 12" Zv2
Mids and highs amp
Sundown 100.4
Sub amp
Sundown 1500D
Battery
Kinetik HC2000
The car.................
Stripping the car down................
that is clean install i have 335I and I just bought the sundown saz1500....is he on the stock alt with no problems at all ?
We added the HC2000 to the stock battery. Still building the car as we speak so once it is all done I will let you know.
i highly recommend swapping out stock battery with largest one you can because the stock alt is prolly over 180a but you might have problems charging both batteries....but i cant wait till u tell me cuz i am hookin up my saz1500d to the stock stereo with a 15
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
428
16
549
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Mike465
Ami Creations
Mike465
Kennesaw, GA
bigbangtheory
Bobbytwonames
    Apr 20, 2024
Bobbytwonames
    Apr 20, 2024
