Volume up, Bass gone!!!!
Marquise
Everytime i turn my reciever up my subs stop bassing....it has just now begun to do this i've had them for about 2 years now and they work perfectly. Its just when i turn it up it goes away. I have 2 12 inch dual subs in box and sony amp 1000w. //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
Make sure you sand the paint off and use a connect that is directly to the body or frame...if you want to take pics of where you're currentlly grounded to, I can tell you if it's a good ground or not.
make sure they are wired correctly, low impedance can make the amp go into protect at higher levels and shut off. but still pay at lower levels.
ok i just sanded the area where my ground is because the person who installed it didnt..........and when i hooked the ground back up to the amp it was a little spark. now there is nothing from my subs
no fuses burned out......i grounded one end to the frame then i disconnected the end from the amp to check it and then tried to hook it back up and it sparked just a little
take everything apart from the amp but the + - an remote an turn it on if it doesnt come on then its a fuse or ground or remote problem. sometimes i jump a wire from the + to the remote just to make sure. then go an check if all the wires are connected i no it sounds dumb but they can look like they are connected but not be. an the spark could have been the caps in the amp charging or the amp blowing....
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
Yeah I did remove the base cap and just straight wire you know grounded to amp and everything how it originally was before the base cap and it...
what ^ said. amp gain setting info, test tones are at the very bottom...
238
Factory. 2021 Chevy Silverado custom trailboss
9
404
Marquise
Marquise
fort worth, tx
quins90lac
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
