First vid of my custom 15 in an 02 civic hatch si
  • 4
yota.coma
who did?
ok so i did have this in my truck for like 3 weeks then wrecked so i put it in my new car 02 civic si
spec: custom built 15" woofer tc sounds based with a team psi recone
dual 2ohm
1500wrms
15"
3inch flatwound coil
2 8inch stiff spiders
sewn leads
6inch dust cap
in 3.5 cubes at34hz going bigger i guess whenever i get time thinking 4.5-5 at 30hz . yes my box is very ugly, i know
i have the "big 2" done with 0ga, a run of 0ga to the back battery. going to do a run of 0ga to the alt to batt to finish the big 3 whenever i feel is isnt a major pain in the a$s
amp is a audiopipe ap1500.1 1500wrms @ 1ohm
I see your sonance 15" on 300watts in a dirty ass van ....and raise you my wife's Sonance 18" on 500 watts....6.0 cubes @ 31hz....
your wifes sonance video is the reason i kept this one. when i first got it i had it in a sealed box and hated it. but i figured i'd try it ported before i passed it on to someone else and love it.
Are there holes in your surround? Try some "amazing goop" glue on them. Works well for me.
no those are just surface scratches. i'm actually considering reconing it when it fianally gives out. but its still intact. i only paid 35 bucks for it because the dustcap was coming loose and audio itch (See local shop reviews) said it was blown.
hey twiistedchild , i got a real amp for it now , let me find a camera that will pick up flex decent and i will make a new video. close to the same amount of flex you got there. btw i am still searching for the arc of the funky pup..........
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
yota.coma
who did?
yota.coma
sylacauga, alabama
stanky1219
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
