The bassmachine (the last chapter)
2loud4youmorris
Ok guys here we go with the last rebuild of the eclipse.
This is going to have all of the following products in it.
(1) Custom Enclosure
(3) 18" TC Sounds Pro 5100 Neo Subwoofer Drivers
(2) Sundown Audio SAZ-3500D Amplifiers
(8) Kinetiks HC16V Batteries (Going to be 6 XS Power D1600's)
(1) Custom 180amp Alt.
All Shok Industries 0 Guage Wiring
(8) Tang Band W2-803SM 2" Drivers
(2) B&C 8PS21 8" Woofers
(4) O2 Audio 6.5" Pro Mids
(1) US Amps AX-4300 Amplifier
ALOT OF BRACING THROUGHOUT THE VEHICLE.(including Mike Singers own line of sound deadening)
Ok guys here are some pics of the front stage that is going in the car.
Each A Pillar will have (4) 2" Tang Bands.
Each door will have (1) 8" B&C Midbass driver and 2 O2 Audio 6.5" speakers
specs on the subs
Specifications: • Power handling: 1,000 watts RMS/4,000 watts peak • VCdia: 4" • Le: 2.8 mH • Impedance: 2 ohms per coil x 2 • Re: 3.02 ohms • Frequency range: 15 - 150 Hz • Fs: 26.5 Hz • SPL: 94.5 dB • Vas: 8.88 cu. ft. • Qms: 6.90 • Qes: 0.25 • Qts: 0.25 • Xmax: 31.0 • Dimensions: Overall diameter 18.52", Cutout diameter 16.83", Depth 11.27" • Weight: 53.4 lbs. Note: All specifications are with voice coils connected in series.
High-temperature low eddy-current stainless steel voicecoil former
2+2 ohm dual voicecoil 4-layer flatwound Aluminum wire, 4" diameter voicecoil
10" linear dual spider suspension with large integral lead-wires
3" long segmented radial NdFeB motor assembly, for low mass and very high BL
FEA designed 3-roll cloth surround for greater than 2.5" peak-to-peak travel
Field-replaceable top assembly system
Large anti-flux-modulation shorting ring
Sandwich acrylic foam fiberglass cone
So I'm split what I should do...I can buy a 2 channel to run my tweets for a 2 way active up front or I can buy a pair of 3-4" mids (off parts...
It was a system from 2 vehicles ago. The enclosure was rock solid. Had a P9 combo to deal with whatever equalization was going to be required.
6
2loud4youmorris
2loud4youmorris
Caro, Michigan
2loud4youmorris
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
