Battery Terminals
Skittles619
First install....having a little trouble connecting the positive for my big 3 and my amp power wire to my + on my battery.
I was wondering if there was a site/ company that sells ring terminals big enough to fit over these posts or what size they are... thank you
I think hes trying to fit wire terminals over the posts that the car electrical connects to.
Is your battery stock or did you buy a new one? Does it only have the post connectors or does it have bolts that goes into it? If you have bolts then yea thats what your gona want to put the wire terminals onto. If its only posts then im thinking you need a battery terminal that will give you bolts also or you can run your wire directly into.
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
6
651
The way it is sitting doesn't seem unsound, just not neat and factory looking. You might be able to come 90 degrees out the side cut away some...
14
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
Skittles619
Skittles619
California
zlibby76
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
