What size aero port for a single 15 SE?
04silverz
San Antonio
I ordered a 3" flared kit from partsexpress but now am thinking it is too small. Did a search on here and it seems pepole recomend 6" aero ports for 15s.
I was at Lowes earlier and looked at the 6" pvs pipes to get an idea and they seemed gargantuan.
Is 4" really not big enough? 6 is required?
Setup is a single RE SE 15 in 4 cubes with about 800 watts or so to it.
Also this is in the back cab area of an ext cab, which way should I have the port face?
I would point it to the driver side rear door. Thats how mine are and they slam. I have 4 10" SE's and this should net you higher numbers on a mic. So subs front port side.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
3K
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
3K
It's a little overkill but hey... https://blackbrickaudio.com/collections/30-000w-amplifiers
11
04silverz
04silverz
San Antonio
RAM_Designs
Mr FaceCaser
    Mar 28, 2024
Mr FaceCaser
    Mar 28, 2024
Latest topics
