Mixing crossovers, mids
  • 3
ydekhtp
Hey everyone, I have a pair of Hertz HSK 165 6.5" mids without the tweeters or crossovers. I have a pair of MB Quart PCE-216 crossovers and I was wondering if the crossovers would possibly work with the HSK mids. I really dont know how this works, semi-newb. Any help would be greatly appreciated.
See if you can locate the specs for the speaker and the crossover. Then you will be able to make an educated evaluation. Now you will be ready to locate a tweeter to match. If all else fails, just try it.
Thank you for all your help and I'll let you know how it all turns out. I'm putting it n a kia optima. I hope that it sounds as good as i think it...
10
Im not sure if this helps or is the correct way but I have 6.5 mids in the front doors and tweets in the pillars I used 2way 6x9s in the rear...
976
that will be $40 my btc wallet is 5748384758585854445... jk! :ROFLMAO:
8
So I did a tone test and found that the tweeters start making sound at about 1500hz which would put the crossover several thousand hertz above...
4
786
ydekhtp
ydekhtp
Los Angeles
James Bang
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
