Got my receiver + speakers, should I connect analog/digital ?
  • 2
  • Participants list
Twistid
I picked up a Sony STR-DG520 and Sony SS-F7000 floor standing speakers , they sound pretty good , definitely a lot louder than my Bose Companion II's lol ... However I have a question...
Right now I have it hooked up with a mini-jack to RCA cable, from my headphone output to the input on the receiver...
The receiver supports digital in, and my Creative X-Fi Xtrememusic soundcard has digital out, so I would need a digital to minijack cable... would it be worth it to connect the computer to receiver with the digital cable ?
What am I losing by using the regular RCA cables instead of Optical Cable ? I think the only difference is the receiver will process the sound instead of the sound card?
Ok, so I should just use the aftermarket sound card to output the analog signal to the receiver?
Here's the sound card that will be doing the processing
http://www.soundblaster.com/products/product.asp?category=1&subcategory=208&product=14066
Right now I'm using onboard audio of my laptop (my computer has not been built yet) and while it gets louder, there is no increase in fidelity or accuracy over the Bose Companion II's ... I assumed it would sound atleast a little better having an aftermarket receiver + speakers instead of just a little all in one two speaker bookshelf system. Hopefully once I'm up and running with the X-Fi Xtrememusic it will sound alot better.
When you random through your music library, you know you got your gear dialed in nicely.
18
Back in the late 90’s, I took my S-10 to Pigeon Forge Tn for the Mini Trucking nationals. The cops there were the worst that I ever seen. They...
Yeah, I'd give them a call. They might replace it. If they do, that is huge CS. I've never known of any mfg to replace an amp because of complete...
17
Twistid
Twistid
in a space out of sound
JimJ
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
