electrical what should i do?
Parker22
IL
Alright so i have a 04 explorer with stock batt. Soon I will be getting a phoenix gold 1200.1 amp. I have a rockford 5001bd now and it dims my lights slightly. Do you guys think I will be okay or will I need to get another battery or what? Do you guys think that little kinetik hc600 would do the trick? Thanks.
i will sell you a battery that will work.
Big 3 would probably do it for you if not already done.
I havent done any installs, how can I see if I have the big 3 done without calling my shop (they are closed today and have done all of my work)
I'm running about 1600 watts rms on a factory battery without any dimming issues. However, I'm not running any massive sub setup, and I DO have 1/0 big three upgrade along with additional 1/0 grounding wires.
^^thanks man. yes i have plenty of batteries models and sizes. PM me with all you have equipment wise and ill suggest a good battery for cheap //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
What amplifiers do you have? What subs? and running @ what Ohm load?What size is your supply wiring to the amp/amplifiers and fuse size under the...
83
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
Update: The burning smell is slowly going away at middle volumes. To the point where it only comes on at middle volumes. I adjusted the sub master...
17
Parker22
Parker22
IL
basscort2009
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
