Panasonic AVCHD HD camcorder
slam
Panasonic AVCHD HDC-SD1 HD camcorder
Panasonic HDC-SD1 1080i HD 3-CCD Digital Camcorder
Used HD camcorder. Has very very little scratches on the bottom. Everything works like it should. It includes:
Battery
Battery Charger
A/c battery cable(does not charge battery)
USB plug
Program to download and edit can be downloaded here:
404 Not Found
465 Shipped or trade. Dont ask what I need cause Iunnno myself
Nowadays, AVCHD is the popular hd(high-definition) video format for DV(Digital-Video)like panasonic, sony, canon, JVC, etc.
Panasonic AVCHD Editor is currently the most superior edit Panasonic AVCHD software, which can edit your
avchd video at your will. Panasonic AVCHD Editor is such a powerful editing software that it provides the intuitive editing function such as trimming, cropping, adjusting effect
and adding watermark. No matter you are a professional or not, you can master it soon. So just download Panasonic AVCHD Editor to have a try.
Friendly tips: AVCHD is a format for the recording and playback of high definition video. Video is compressed in MPEG-4 AVC/H.264 format, and audio is recorded in Dolby Digital.
Trim Video
step 1 After you add the file(s), clicktrimbutton on the toolbar to open Trim window.
step 2 Click Play button to play the selected file. When it comes to the very start point you want, click Set Start Point button to set it as start point. And when it comes to the end
point you want, click Set End Point button to set it as end point.
Tips: You can drag the slider or enter the time value you want in the Start and End textbox to adjust the position of start and end point.
step 3 After the trimming setting, click OK button to return to the main interface.
edit Edit Video Effects
step 1 Click edit button button on the toolbar to open Effect window.
step 2 Check Enable Crop check box, click the up and down arrow to adjust the height and width of the crop area, click the up and down arrow of Left Margin and Top Margin to
adjust the left margin and top margin of the crop area.
Tips:
1.Click Restore Defaults button, to restore the default settings.
2.Adjust crop area by drag and drop: drag the central handle and surrounding handles in the preview window to adjust the crop area.
step 3 Check Enable Effect check box, set brightness, contrast, Saturation and choose one effect for your video.
step 4 Check Enable Watermark check box, add text or image watermark for your video.
By setting all the parameters, you will get expectant effects in a short time. Edit Panasonic AVCHD is so easy, so just don't hesitate to download Panasonic AVCHD Editor and have a try by yourself right now.
AVCHD Converter is a top-rated and professional high-definition video program which provides you a good solution to convert hd videos(AVCHD (mts, m2ts), TS, H.264/AVC, MKV) from HD-Cameras to various common videos like avi, mpeg, dvd, divx, mov, wmv, mp4, mpeg, mpeg4, etc. Also supports extract audio from HD video, and convert among audios as well!
With powerful converting engine embeded, the AVCHD Converter is highly praised by Mac users to convert AVCHD files to various video audio formats on Mac and on Windows with fast speed and great output image and sound quality!
The light at the end of the tunnel for AVCHD editing is growing brighter as AVCWare AVCHD Video Editors was recently introduced.
AVCHD Editor , as a professional editor software, can edit AVCHD file like video cropping, movie trimming, and video effect adjustment. Advanced AVCHD settings, such as Video Size, Bitrate, Aspect Ratio are also supplied.
Besides, AVCHD Editor allow Camcorde users to convert avchd video to other popular video formats, like AVI, MPEG, WMV, DivX, MP4, H.264/AVC, MKV, RM, MOV, XviD, 3GP, FLV, etc.
slam
slam
fort worth, tx
HSWaypeType
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
