2nd Gen Explorer Sub/Port Placement
  • 4
I am lookin to run (2) 12"s and wanted to know what you all have had best results at the head with with this sort of setup
Reading > Yall
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
depends on org mic placement ect... prolly best to post up on their site
Like i said here... again, prolly best to ask there on their site.... of the orgs forum...
you will get responses here like the one above that have no expriience at the head rest.
//content.invisioncic.com/y282845/emoticons/read.gif.ff512c499c00ed3faae9a20f4b088b29.gif
In mine with 2 subs its both back port drivers side.
Depending on which headrest you meter at, you might try firing port too drivers...but i meter in drivers kick so i fire too pass side, and subs back on drivers side.
he is an ext cab truck guy tho, Bud used to be on his team and had an expo so ben told me the secrets he knew from him but he ran totally different equipment/install. Tubes instead of a box
Yeah. Same thing here. The under seat box I did for the 8s was 325$. He’d already wasted that much with 2 prefabs that sounded like ass.
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
jshak07
148.4 and climbing
jshak07
louisville
jshak07
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
