Two sources... one output?
  • 1
CadillacMatt
Disturbing the Peace
Hey guys I have a little project I need help with.
I recently purchased a new head unit with a monitor, replacing my old Pioneer 4000UB with iPod control. The new unit only has RCA Aux-In and does not offer iPod integration.
What I am trying to accomplish is have my iPod play audio output through the sound system (two amps - one for mids/highs and one for subs) independent of the head unit, so I can play videos/movies on the head unit while still having the option to listen to a different track than what's being outputted from the movie... if that makes sense.
It would be an easy solution to plug the iPod directly to the Aux-In of the head unit but then the screens would just display a blue screen while in that mode...
I was thinking of running the iPod output through a powered equalizer (the dock connector output of the iPod gives the best quality but it's not powered like the headphone jack, so it needs a preamp and a volume control) and then back to the amps, but that means I would need some kind of two input/one output RCA splitter for each channel on the amp, and I heard that it was not a good idea to combine sources like that... even if you are only playing one at a time, they say that they will short each other out?
The only other option I was considering was to take the outputs from the HU, and the outputs from the iPod/crossover, and running them into an RCA switcher box... but even then, most switcher boxes only have 3 RCA inputs (R, W, and Y) and I would need at least 5 for all of the amp connections... so confusing...
Thanks if anyone can help!
Hello! i have too problems with head units, two cars, old mazda 323f ba and now mazda 6 2007r station. Problem is from lossing quality, poor bass...
4
939
I have a 2012 Ford F150 Platinum Crew Cab. I was saying that since my secondary battery would be grounded to the frame could I not ground my amps...
4
Which amp and which speakers? What crossover are you using? You may be fine so long as you never push the volume too hard.
12
909
CadillacMatt
CadillacMatt
San Antonio, TX
CadillacMatt
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
Latest topics
