Picked up large SUV, where should I add speakers?
TheJuggla1
Surrey BC
Here is a diagram I found of an older one on the internet
http://i233.photobucket.com/albums/ee268/Allan-2greasy/suburban.jpg?t=1250265352
Right now I am planning on salvaging my old system which consists of 2X 15" Kickers(pretty much new) 6" Kicker + Tweeter (Again pretty much new) An some pretty old 6x9(Probably getting to the end of their life) 1000 RMS Watt Mono Alpine(Also very new) And a 4 Channel Amp with 50 RMS Watts each channel(This amps fairly old but holding together pretty nicely, but the other 2 channel one I bought with it died a while ago) And one of the newer Alpine HUs that has Ipod plug ect.
First thing I rear my HU gives out quite a bit of watts(Think around 100), but since its a HU it will just be mostly distortion? Or could it be something I could actually use because its a higher end Alpine?(I forget the actual model, its the one that plays CDs, has the ipod hook up that hooks into the bottom of the IPod where you charge it, 6 buttons instead of the 4 like the cheaper ones have - changes color on these buttons, and 3 sets of RCAs)
I wanna make this vehicle just bumping, loud as ****, but larger speakers lose quality correct?
I'm putting the 6" + Tweeters(Tweeters sit in the actual speaker) In the front doors, and the 6x9 in the very back above the rear doors facing forward. Subs in the back obviously, I think if lay them down and I face them up I won't loose my rear seat or my view out the back, suggestions on adding other speakers? Not worth it to add any more?
There's no sense in adding a hundred speakers. You should be satisfied with how loud your system is, especially if you're making a transition from a car to an suv.
Will I get any louder? Its a huge area for sound, I think It will sound less loud now.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
911
was never registered on the road so no, here in maine for a vehicle of that age all you need is a bill of sale. i still have original dealer...
327
No need. If it's a 4ohm DVC, then it should be wired to 2 ohms at the enclosure terminals. That would verify that the coils are good, and the...
15
TheJuggla1
TheJuggla1
Surrey BC
groundpound4200
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
