Sub Box Rattle driving me crazy...help please.
Ksan
Dodge HEMI
Ok, guys i have my Sub box under the read seat of my 2004 dodge quad cab with the 12 inch ID V3's in it. They sound so good........EXCEPT for the vibration from the sub box sitting on the floor and reverbrating all over the place. Any way at all to fix this? Thanks for the help. I thought about putting dynamat betweens the box and the floor but I never used it not sure what it is for? Sound deadning? but would it help with this? Foam maybe? Thanks.
Box is MDF 3/4 inch sealed.
how about securing the box to peice of mdf thats coverd in like half inch rubber of some sort ive done that in a car with an under seat sub and it worked
Thanks for the quick replys. Yes I can secure it to the floor if it needs that. The rubber is a great Idea, I have very little room but maybe rubber under it and then secure it down would do the trick you think?
that should prob do the trick. is the box carpeted?
Yes sir the box is carpeted but it vibraits so bad you can't hear anything but that and it sounds like c&@p. when it does that. I didn't know how to fix it. I can move the box around and it will sound great but then it will start to vibrate off the floor again in a few minutes and sounds bad again.
yea the car that i mentioned in an earlier post was the same deal. you need to find some way of securing the box down and possibly getting the rubber under the box like i suggested before
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
16
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
A little DAP will do ya, drill, feed & seal, done.
564
Ksan
Dodge HEMI
Ksan
Louisianna
phemps
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
