head unit advice for a noob
statonburrell
The 800PRS is a superior model... Neither of those units will have perfect output voltage for your amplifier applications, but they should work acceptable. Pre-Out voltage tends to be low on the Pioneer models unfortunately.
If you need additional help, tech support, or purchasing; simply email me at PerformanceAutoAcc@GMail.com. Happy to help!
The 800PRS is an "audiophile" grade head unit. The 8000BT has some nice features, but it's definitely a step down from the 800PRS. If you want SQ go with the 800PRS. If you want a double din unit and you don't care about having a ton of features and controls, go with the 8000BT; it is cheaper. I can't say enough positive things about my 800PRS.
I blew the pico fuse on multiple Pioneer decks and they changed to thin wiring on their harnesses so went to Kenwood. I never used Network Mode...
Thank you for the reply and compliment- it’s a cool rig - but like anything you take over - you’re left to clean up someone else’s mess. Took...
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
432
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
statonburrell
statonburrell
Lexington, SC
ejschultz
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
