Another Type AArrrgh enclosure build
waseem
finally have started to build box for my 2 aarghs, about 4cuft at 35hz with about 72 sq inches of port.
this is my first ever box build let alone first ever woodwork project that wasn't from school so not gonna be real clean. gonna be powered by 1500rms, so hopefully will sound good in the end.
it will be braced with 45s in each corner, will have lengths of pine to brace top to bottom and front to back and will be double baffled. The subs will be firing up and the port will be firing back because the car is a wagon.
For the double baffle, is it better to have the driver screwed into the first board of the baffle and then the next board of the baffle around the sub so that it is flush, or just cut the holes for the sub the same size on both boards of the baffle and screw in so that it is not flush. Is one way stronger than the other? (probably a stupid question right?)
heres the pics so far
cutting it up
thanks guys
continued pics
sleeping on the job
gangsta baffle chain
i like glue
basically done
having a try of the new toilet
yea i know the sub holes don't look good, it was my first time doing it so get off my back! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
now just got to sand everything down nicely, and wait for silicon to dry, hopefully it will actually work lol
thnx guys, yea probably going to be painted
my friend wants to do something like this but looks pretty hard
lol he likes alpine a lot
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
waseem
waseem
Brisbane, QLD
waseem
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
