WTT 4000 watt Subwoofer!!!
chadwick_13
Suppp Everyone, I own a 15 Inch Cerwin Vega Stroker competition Sub. Its 4000 Watts!! with 2 Ohms. It can easily take out people with 2 or more subs in their ride..its in great working condition. Here are some pictures.
P.S if your interested i can post a video of the Sub in action! just let me know/ i also own a 4000 watt pyramid signature series Amp that i might throw in with the sub if i get a good price or reasonable trade offer! Thanks!!!
- Gabe
i pulled these specs of the cerwin vega website for this model sub!
• Peak Power Handling: 4000 watts
• Program Power Handling: 2000 watts
• Sensitivity: 86 dB 1w/1m
• Ellipsoid Surround
• Integrated Voice Coil Heat Sinking and Modulation Ring
• Extremely High-Temp Dual Coil Design
• Dual Gap Motor Design
• Surround Clamping Ring
• Spider Clamping Ring with Integrated Speaker Terminals
• Axial Edge Surround System
• Field Replaceable Cone Assembly
DIMENSIONS
Mounting Diameter: 16.25" (412.8 mm)
Mounting Depth: 9" (228.6 mm)
Weight: 34 lbs. (15.42 kg)
yeah its 34lbs on the scale but feels about 50 lbs! but on the other hand you don't have to worry about it weighing down the car that much....and 200 is a lil low..looking about 350+ Thanks!
next to a tv ? no idea lol...maybe you should start a thread with that question lol...but no it doesn't sit next to a t.v. i just placed it next to the Telly to take a photo so you can compare sizes yaa diggg!
Thanks!
How many watts does that sub put out 2000 or 4000 //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I didnt think subs put out watts **** i want that thing if it puts out 4000 watts will push my btl awesome lol Just messing wit ya //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
with a wack ass amp it most likely push 2000+ watts..its Max is 4000 so if you have a Good Amp like JL, Hifonics..etc you'll then be pushing about 4000 watts
  • Locked
Up for grabs is a Gravity Warzone 4000.1 mono amp. This is a solid low budget sub amp that does a solid 1000 or so watts at 1 ohm, maybe a bit...
Have you tried connecting the amp to a car battery? No subs, just power. If it protects, amp is bad. If no protect, subs/wiring or ATX power...
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
5
chadwick_13
chadwick_13
San Diego
amartin_72
Doxquzme
    Apr 13, 2024
1aespinoza
    Apr 13, 2024
Latest topics
