Sealed box help
  • 5
thebread
I'm relatively new to car audio. I have a 4ch amp and some aftermarket speakers. However I don't have a sub stage yet and I'm looking into it right now. I plan on getting an IDQv2 12". I want a SQ sub and that seems to fit the bill. I've been looking around for specs on the box best suited for it. I also plan on making the box(sealed). The dimensions I plan on using are 20" wide, 16" tall, a top depth of 7.125" and a bottom depth of 8.125". I'm looking for an end result of about .88ft^3. The speaker displacement is .07 ft^3. With those dimensions I end up with around .88ft^3 net. But I don't think I'm accounting for the 3/4" MDF. Can someone tell me what exactly I need to do before designing my box.
Thanks.
Sorry for wall of text...
How do you figure?
I did me some Maths //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
(Length - 1.5) * (Width - 1.5) * (Height - 1.5) = Volume / 1728 = Cubic Feet
it would be a lot easier to build if you made it a straight rectangle. no angle cuts to worry about making and sealing it up good would be a snap.
Oops... reading > me. I didn't notice the 4th measurement //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Yeah, I was thinking that myself, and was just going to make 1 depth of 7.625 as opposed to the wedge design.
What he said... Any damping of over 80 is fine, 200 is really good, so 1000 is like my 80lb home audio amp! Unless you are using certified Hi-res...
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
thebread
thebread
Bay City, MI
thebread
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
