why dont subwoofers....
why dont subwoofers more commonly have bumped top/bottom plates? (Like the new BTL's large bottom plate, and the old BTL's tall top plate?) Could these two be combined?
wouldnt more travel of the voicecoil lead to more x-max?
I'm guessing it has something to do with how bass is reproduced in comparison to the linearity of the stroke?
I just figured if a motor had these two things integrated it could have some serious x-max and possibly low-end monsters?. Any comments or info would be appreciated.
Code:
http://blog.sounddomain.com/photos/fi/dsc02882.jpg
Code:
http://i100.photobucket.com/albums/m34/jonny101abc/Picture010.jpg
= ear sex ?
Xmax is dependent upon the geometry of the coil and the gap and control of the magnetic flux within the gap. In an overhung motor a taller topplate requires a longer coil to maintain the same amount of Xmax. Taller is not necessarily better as far as the coil is concerned as there are trade-offs here (higher inductance, more mass, etc).
Having a bumped backplate/etc may give the coil more travel before damage occurs (Xmech), but it won't change the amount of linear stroke the driver is capable of. Now, that said, the design of the backplate will affect how the flux "flows" through the motor.....but that doesn't mean that thick bumped is necessarily better than another design for a particular motor.
The bottom pictures looks more like the older XXX than it does the previous BTL (going from memory). In which case, the top plate is so thick on the XXX because it's an XBL^2 motor.....which means the coil is shorter than top plate.
This isn't a highly detailed post, but it should give you the jist of things. It really comes down to the goals of the design and the best way to acheive those goals. Everything is a trade off, and you just have the select the most appropriate set of trade offs for your design goals and target price.
Just to hammer home the point:
Steel = teh spensive. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Many subs use thicker magnet stacks to allow for x-mech -- stacking the third slug on most motors doesn't add alot of motor force but is cheaper than adding that much more back plate.
Lighten up man, it's all in good fun. Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why...
942
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
914
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Cool down, bro. and have a happy thanksgiving. I was merely inquiring in response to someone else's post that cautioned about clicking on the...
AVSTANG02
Banned
AVSTANG02
Las Vegas
sundownz
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
