need help on my 880prs
  • 3
Juice0723
Canada
Hey,
My 880prs HU is cutting out when playing a cd or mp3 cd. I thought it may be because of the bass making it skip cds. Or low voltage to the HU. The music just stops for about a second or two. Then the music plays again and keeps doing it when I have the volume pretty high. You guys have any suggestions?
Thanks.
sometime the temperature can eff up the ways cd's work, and sometimes the CD's will build up moisture.
Im sure that you have tried wiping the disks off before you use them allready tho.
That headunit will display the voltage in the menu, so you should be able to check if that could be a problem
yeah I tried multiple cds and wiped them off. I use the voltage display as well. Whats the operating voltage for this HU?
11
242
520
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
800
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
Juice0723
Juice0723
Canada
galacticmonkey
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
