Ipod Touch
vibe 700.1
SPECS
# 1 x 150 Watts RMS @ 4 Ohms
# 1 x 250 Watts RMS @ 2 Ohms
# 1 x 400 Watts RMS @ 1.3 Ohms
# 1 x 700 Watts Max @1.3 Ohms Bridged
# 1 Ohm Stable
# MOSFET Power Supply
# PWM(Pulse-Width-Modulated) System
# Bi-Ampable Strapping
# Glass Epoxy PCB
# Gold Plated RCA Inputs/Line outs
# Input sensitivity : 200mV~8V
# Variable Low Pass Filter : 50Hz~150Hz 24dB/Octave
# Variable Subsonic Filter : 15Hz~40Hz 24dB/Octave
# Variable Bass Boost Control : 0~+18dB
# Phase Control 0~180 degree
# THD : 0.1%
# S/N Ratio : 90dB
# Remote Subwoofer Bass Control
# Frequency Response : 15Hz~150Hz
# Input Impedance : 10K Ohms
# Heavy Duty Power Coated Heatsink
# Custom Terminal Block for Speaker Connections
# Thermal, Overload Short Protection
# Soft Turn-on/Turn-off
# Fuse: 20A x 2
# Dimensions : 10.25''(W) x 2.36''(H) x 10''(L)
kdc-mp238
http://www.crutchfield.com/p_113MP238/Kenwood-KDC-MP238.html?search=kdcmp238&tp=5684
pm me if interested
I would turn it to either flat, or better yet off if you have that option and use the head unit to control the eq.
I had to go from the headphone jack to an rca converter and plug into the back of my head unit. My old iPod won’t directly connect on any of my...
902
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
631
I pick up hitchhikers...if they know "the rules of the road" 🤣🤣🤣
adam007
U guys are silly
adam007
Michigan
adam007
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
