12" sub
about 97 percent of people here are gonna tell you to build your own, and yes for ported prefabs are more expensive than sealed. and it all depends on the sub you buy; some subs like sealed more than ported and others dont it all really comes down to the sub
from what i've seen 12" sealed is like 1-1.5cf and ported is 2-2.5cf. It really does depend on the sub tho.
It really depends on the sub. Alpine recommends 1.3 cubic feet for their 12" type R while a box build that I'm doing for Dave_damage's SS T4's recommend 2-4 cubic feet PER SUB lol. 2 being smallest, 3 being recommended, and 4 being max. So yeah, definitely find out from the manufacturer what the recommended volume is as it can vary quite vastly.
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
482
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
4
339
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
483
Master69
Master69
Burlington, Iowa
DNick454
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
