box size@ported or sealed
  • 5
yes not sure on the specs since I wouldn't use anything fosgate if you paid me too. but 1.9 is way too small for that sub. even sealed. you want roughly at least 3 -4 ported at 35-38
Taken straight from the RF site:
Rec. Vented Enclosure 2.66 cu. ft. (75.32 liters)
Vented Tuning Frequency 32 Hz
Port: (1) 4" diam. x 10" long
Port: (1) 10.16 cm x 25.40 cm
Taken straight from the RF site:Rec. Vented Enclosure 2.66 cu. ft. (75.32 liters)
so by me going to 5.66cu.ft ported tuned to 38 hertz will i be louder than the recommened sealed box.
those tiny little box specs seem like a way for fosgate to save on some warranty returns. if you run it through winisd, you'd probably find a far larger number. 5.66 sounds like a better number than 2.66 for a 15.
2.66 cu ft for a 15 is way too small. I'd shoot for around 5 cu ft. net with like 50 sq in. of port area, then simply tune it to whatever your listening preference is.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
3K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Try the sealed then. If you feel you're lacking low end extension you might try to build a ported box to give you a little more output down low.
7
Fosgate1
Fosgate1
williamstown,ky
DNick454
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
