Jump to content
Sign in to follow this
gqjeff
precision port 90 degree elbow
Recommended Posts
I got my 4" port today but I need to use a 90. I went and checked out the standard 90 4" pvc ones and they do not fit at all. How or where are people making these work or getting ones that will? I need to use the flare at the end also and I see dayton make a male to female one so is that what I need?
DEH-P980BT
DC Level 4 10" at 33 Hz in 1.4 Cu Ported
Sundown SAE 1000D
Focal K2P's
Sundown SAX 100.2
Big 3 1/0 gauge
Kinetik HC2000 front HC600 rear
01 pimped out Jetta GLX
Some feedback.. Not much I am new here. I have 100% on ebay at gqjeffy and a very good rep on some other saltwater reef forums...
http://www.caraudio.com/forum/showthread.php?t=388322
Share this post
Link to post
Share on other sites
Well the Dayton ones will not work just got off the phone with parts-express. So how are you guys sealing them together using standard PVC 4"? Could I use some type of gasget then use plumbers goop or something to fill the void and sill it?
Thanks, Jeff
DEH-P980BT
Sundown SAE 1000D
Focal K2P's
Sundown SAX 100.2
Big 3 1/0 gauge
Share this post
Link to post
I have never had luck putting any angles on thin wall pvc.
Mike Schwitz
Installer/ Fabricator
Audio Video Extremes
Waite Park, MN
320-217-5877
Share this post
Link to post
Yea that's what I am afraid of plus the weight of the 4" pvc elbow on the thin wall. How are others doing it?
DEH-P980BT
Sundown SAE 1000D
Focal K2P's
Sundown SAX 100.2
Big 3 1/0 gauge
Share this post
Link to post
make part of the port outside the box
Silver HHR - 155.1 db
TEAM SOUNDSTREAM
XS Power
REFS:jeeper07,thegreatestpenn,TeamPSI(x3),dbman150,bad @SS chevy,tommyk90,*GQ*,THXdts, XxSuperAdamxX,fatboyracing,gymfreak101,LTnChynadoll,amartin_72,avs20,Twisted_0912
SOLD TO: Kold_Killa,GMCJimmyslt2000,skitzafit,ravens9322,wErd,jeramydean,Shinju,the12voltsux,gammey4,camaroaudio69,bigwheel15
TRADED: RnK1026,wasted ink
Share this post
Link to post
IIRC, the precision port tubing is 1/16" thick. That makes the OD 4-1/8. Sch 40 PVC is 4-1/2 I think. You can get closer by using SDR35 sewer application PVC. The pipe has a thinner wall, still thicker than the P-P's. You could wrap the P-P tube with tape or thin deadener to take up the slack and create a tight fit.
Share this post
Link to post
Ok cool I am going to check it out.
TY, Jeff
DEH-P980BT
Sundown SAE 1000D
Focal K2P's
Sundown SAX 100.2
Big 3 1/0 gauge
Share this post
Link to post
yeah try that sewer pipe I know there is a pvc that will fit go to a supply house with it and look at some. if you are in the northwest suburbs go to wagner and sons in wheeling or it might be prospect heights
O my liver!!!!!!!!!!!!!!!!!!!
Share this post
Link to post
How about cutting each end at a 45 degree angle using a miter box. CA and/or hot glue the pcs together. Use caulk to seal the joint and, if possible, sand the joint lightly on the inside.
:crazy:
Share this post
Link to post
I found the sewer pipe pvc and that is going to work good. It adds 6.5" of port length also. I need 20.23 so this actually works out great.
DEH-P980BT
Sundown SAE 1000D
Focal K2P's
Sundown SAX 100.2
Big 3 1/0 gauge
Share this post
Link to post
the 90 ads more that actually length to the tuning I forget how much I hope someone can find the formula that tells the restriction to it and how much to cut off because of it. It is similar to like when you make a labyrinth slot port.
Share this post
Link to post
Yea I def hope someone chimes in if that is the case...
DEH-P980BT
Sundown SAE 1000D
Focal K2P's
Sundown SAX 100.2
Big 3 1/0 gauge
Share this post
Link to post
with one 90 it is not gunna be much difference but a little. try to see if you can find and fit long sweep fittings. less restriction and acts more like a straight piece.
Share this post
Link to post
Here is the 90 and this is how I was told to measure it. That is where I got the 6.5 to add to the port length.
DEH-P980BT
Sundown SAE 1000D
Focal K2P's
Sundown SAX 100.2
Big 3 1/0 gauge
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new FREE account
Sign in
Already have an account? Sign in here.
Sign In Now
