jayisking's 03 corolla build
jayisking
Its pretty much done but there is still little things that need to be done, equipment:
two fi bl 15's
kicker kx2500
3 pairs of alpine type r speakers(2 6.5" comps 1 6x9)
alpine mrv-f345
kicker hyperflex 1/0 (including big 3)
fatmat through out the trunk but not the lid
and some spectrum sludge comes on monday...
SICKKK u can fit 2 15's in that bishh?
hot ****. i got an 03 civic. i can probably fit them hoes in there too.
whats the dims for ur box? and cu ft?
SICKKK u can fit 2 15's in that bishh? hot ****. i got an 03 civic. i can probably fit them hoes in there too.
33 wide 27 long and 16 tall and idk the cubes it is but its too small for the subs. sounds amazing though.
That's a lot of rear fill... I'd lose the rear deck speakers, personally. And maybe clean up the wiring a bit?
Otherwise, looks loud.
i definately need to clean it up but dont have enough wire to do anything right now. Like i said theres still a some stuff that needs to be done.
huge trunk you should try facing those subs forward and port forward should be alot louder
i tried but theres just not enough room to do that with these dimensions
That is alot of rear fill, but to each his own, looks great so far.
I saw the title and expected a wall, would have never figured it be enough room in the trunk for the subs ported. Whats the specs of that box?
That's some serious poundage u have there,feel sorry for the rear deck speakers.Lose 'em ,ur already improvising with speakers in the rear doors which is not stock .
nice to see someone else with a corolla //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
my box dimensions are 32.25 wide 14.5 high and like 33 inch deep //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
These are the parts I think I need, can someone let me know if this looks right? Headunit: 9" Toyota Corolla 2003-2008 Android 10 QUAD CORE Door...
I just bought a pair of SoundQubed QP-MR6.5 speakers powered by my Taramps DS440x4. My 6x9s blew when I got the amp because I tried to tune the...
You're going to run into some issues with weight on the arse end of your car at some point and there's a limit to how much suspension...
Check out Focal. I believe they have direct replacements for many Toyota's...
Make sure they provide a warranty for theyre work and everything you buy.Ask to keep all the Boxes that every amp and speaker and sub comes in...
jayisking
jayisking
vondocha
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
