Alpine 9887 settings with passive xovers & sub
linksyz
Hey guys... I installed my system today and I didn't like the way it sounds at all //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I am kind of a newb to car audio :\
I have Focal 165 K2Ps in kick panels (midbass and tweeter next to each other) running passive off of bridged Alpine PDX 4.150 (200x2wrms) and DLS Iridium 10" sub in the back running off of Alpine PDX 1.600.
I didn't change the setting from the guy that I bought the HU from and I believe that it's currently set to 2.2ch (3WAY) and not 4.2ch (F/R/Sub) as there is no option for Fader.
Is my system supposed to be 4.2ch (F/R/Sub)? Also, should I use Parametric or Graphic EQ? What settings should I use in either Parametric or Graphic EQ (slopes, etc)? And what are the crossover points I should use running passive? Just HPF for comps at 80hz? Any help would be appreciated //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
By the way... if anyone needs any help from the manual that doesn't really help me.. here are the links:
Alpine CDA- 9887: http://www.manualnguide.com/manual-get/13350/
Alpine PDX 4.150: http://www.manualnguide.com/manual-get/3295/
Yes for passive you run it in F/R/Sub mode. Just use the front set of rca's off the HU. Leave the rear disconnected and capped (so they dont touch anything).
Leave the front amp set to full-range, turn off any filters on the sub amp too. Let the HU do all the processing.
Im not real sure how Alpine HU EQ's work, but good starting points are 80hz 12db HP to the front and 60-80hz LP for the sub.
If the HU still has old settings in it I would try to do a reset if you can.
What exactly dont you like about the setup?
Thanks Mike! Will it be a problem if I have the rear RCAs plugged in? It would be PITA to unbolt the amp rack and unplug/tape off RCAs.
Well the sub sounds real nice but front stage doesn't sound good at all... I'll have to change it to F/R/Sub-W first as it's currently in a 3-way setup. Once I change that and put the HP on fronts and LP on sub... I'll let you know how it is. I should do that on lunch time in an hour or so. I can stop by Mandarin sometimes this week so you check it out if you want to.
What are the rear RCA's plugged in to?
And yeah you really need to change in to F/R/Sub when running passive.
By the way in F/R/Sub-W and L=R setting in 9887 there are these crossover setting items:
LOW (SUB-W) / MID (REAR) / HIGH (FRONT).
So I need to set LOW to 63hz and MID to 80hz?
Will those be LPF and HPF?
This is how I have the head unit and amp set up:
1+2/3+4 switch
Channels 1 and 3: positive wires
channels 2 and 4: negative wires
Head Unit Color
Left Rear Blue
Left Front White
Right Rear Black
Right Front Red
Amp Color
Channel 1 Blue
Channel 2 White
Channel 3 Black
Channel 4 Red
Right RED
Left WHITE
Channel 1 and 2 White
Channel 3 and 4 Red
It shouldnt be that way. Low, Mid, High is for running active ONLY. You need to be sure the HU is in F/R/Sub mode first.
Is the head unit still in the 3 way set up? If you want to change that, there's a switch on the bottom of the head unit to change it. There should also be a switch to change the Ai-net to EQ mode as well for an external EQ.
x2 on this, flip the little switch on the bottom to get it setup for a passive system. It sounds like you simply went from L≠R to L=R Once the switch on the bottom is flipped you should be able to start tuning.
Okay so I changed it to F/R/Sub and I set:
LOW: 80hz FLAT
MID: 80HZ 12dB
and it sounds much nicer! Do I have to change any other settings while running passive?
This weekend I will be taking actual pictures for other sites. So grab it before its gone
481
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
538
linksyz
linksyz
Jacksonville, FL
ejschultz
Random4thGuy
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
