Xprime4 10+ year member
****in' canadian
I'm switching subs //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif again
This time, i'm going with 2 15 inch Audioque sd2.5 dvc 4ohm hooked on a bxi2006d.
The box will be 37.25 lenght x 23 deep x 18.5 height for a total of 7.5 before drivers / port displacement. It's a bit on the short side so i might use the wheel pit if possible, but not for now.
i've draw a first attemp
I'll be using the side of the box for the port, coz that's the only way i'll get clearance. how long and and wide should the port be for a 36hz tuning? any problem with the port facing each other? the box is only 23 deep - 15inch driver - 1.5 wood, so that's why i want to use both side and less wide port. I don't know how much port area i need tough
thank you
thank you
