Powering RE SE 10" $150-200
BassFreak01
I just ordered a RE audio SE D4 sub and im lookin for somethin nice to power it at 2 ohms... it will be going in a sealed box i am building in woods class and yes it is to the right air space. i have looked at kicker and phoenix gold so far... any other recommendations i am sorta new to car audio. budget is 150 to 200
You need something that will give you 600 watts RMS @ 2 ohms. **THIS** amp may end up over budget after shipping and will give you about 750 clean watts @ 2 ohms.
If you know how to set your gains, it will not be a problem.
yea those look pretty nice i think the PG amps look nice for the money, but i could go up to about 250 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif so keep them comin guys!
SEs are amazing subs! They need more then 600 though... 750-800 is perfect. If you can push your budget up to $236, you shoud get a referb zx750.1 and set the gains. you'll thank me later
HERE
thanks guys i did look at both of those at one point they both look nice! but i was gonna ask about the power handling thanks for that info i wanna throw all i can throw at them!
My experience says that for most people, usually, overpowering subs doesn't really gain much, especially for daily or music. Actual power levels...
620
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
When you say power on for a limited time, do you mean power after the vehicle has been shut off or just turning on the radio and it plays for a...
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to...
BassFreak01
BassFreak01
B-town, Iowa
macq32
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
