Im looking for two ten inch subs that will run good off of a 800 watt pioneer amp.
I was thinking of getting JL Audio 10W1v2 4 ohm. Anyone hear any good or bad things about these subs or have any good suggestions for 10 inch subs that are under 100 a piece?
JL Audio 10W1v2-4
Technical Specification
* Sensitivity: 84.53 dB
* RMS Power Range : 150 Watts
* Peak Power Handling: 300 Watts
* Impedance: 4 Ohm
* Diameter: 10 Inch
Features
* 10" W1 version 2 4-ohm subwoofer
* Continuous Power Handling (Pt): 150 Watts RMS
* Nominal Impedance (Znom): Single 4 ohm
* One-Way, Linear Excursion (Xmax)*: 0.375 inches / 9.5 mm
* Nominal Diameter: 10.0 inches / 250 mm
* Overall Diameter: 10.5 inches / 267 mm
* Mounting Depth: 4.34 inches / 110 mm
* Net Weight: 7.81 lbs. / 3.54 Kg
* Driver Displacement: 0.025 cu. ft. net / 0.71 liters
* Rec. Sealed Enclosure: 0.625 cu. ft. net / 17.7 liters
* Rec. Ported Enclosure: 1.00 cu. ft. net / 28.3 liters, tune to 31 Hz
JL Audio 10W1v2-4
* Impedance: 4 Ohm
* Diameter: 10 Inch
Features
