Hooking up a pc to my head unit
  • 6
Intel91
I want to try and hook up a permanent pc in my car to my head unit so I can see my pc display on my head unit. I have a VM9512HD Head unit. I know how to hook up my computer to the av in. My problem lies in that I also want to use the touchscreen to control my computers mouse. There is a black cable coming from my head unit that looks like an rca jack that seems to be a touchscreen interface. My question is basically, how can I control my pc using my touchscreen head unit. I plan on using a separate small wireless keyboard for typing.
Thanks.
Thanks.
There are no wires coming out of the back of any touch screen "that I know of" that allows you to hook something up to use the touch screen with' You are probably looking at a s-vide in.
Thanks.
couldnt resist
jensen VM9512HD
get a touch screen monitor get a carputer bam, I think actually i know theres no way a jensen unit let alone any is going to be able to control a PC from the touch screen
Its not svid. It literally looks like an rca jack. It is a black wire, and says touchscreen on it. I am pretty sure the wire is supposed to be used to addon a nav unit and allow the nav to interface with the touchscreen. I dont care about nav, so I was just wondering if there was an adapter and driver that would allow it to interface with the computer.
I guess I'll see if I can make an adapter and write a driver for the comp that might work. If not Ill just interface the computer with the monitor without the touchscreen and use a mini keyboard with a built in mouse trackball.
Thanks.
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
264
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
531
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
781
Intel91
Intel91
Destin, Fl
Intel91
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
